Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
Body work on the front fenders is done.....well, unless I decide to add some lights on top. Not sure about that just yet. It took several layers of filler primer and loads of sanding, but I'm pretty pleased with the result. The veritcal sides of the fenders are still rather rough, but I have no good way to sand those surfaces. Hopefully it won't be too obvious after paint and clear is applied....
![]() Sorted the steering, as well. Used a short Losi aluminum servo arm (I don't like using plastic bits) and put the tie rod under the knuckles. Bumpsteer is minimal and clearances under bump travel are good. ![]() Took a file to the knuckles to get a bit more steering out of the TLT axle. ![]() ![]() Ackerman looks pretty decent. My thumbs says hello! ![]() |
Wow !! fenders look great. What primer did you use?
Thanks!! I just used some automotive filler primer I picked up from Advance Auto Parts. I'll see if I can get the manufacturer, but it wasn't anything special. But it did take about half a dozen rounds of priming/sanding to get it looking acceptable.
Since there have been no updates on the shipment of my tires and front wheels from Stella Models in Hong Kong, they suggested that I initiate a dispute via PayPal. On Friday I did just that and then ordered the same tires/wheels from Semi Joe. For the same overall cost I got it delivered in record time!! Great customer service and I'll remember that for sure.
All wheels/tires are made by Lesu. Pretty happy with them overall, except for a couple things.
Here's the rears all mounted up. ![]() Fronts mounted up. ![]() Sorry for the crappy lighting, but I'm pleasantly surprised that the ride height looks pretty good. The front is only a bit higher than the rear, which is surprising given the front TLT axle. Once I add some weight in the form of electronics, battery, speaker, etc. then it may actually sit level! Schwing! ![]() So I started mock up of the front fenders. Overall, I'm pretty happy with this positioning. Keep in mind the axle swings rearward under compression. I'll need to add some styrene under the hood sides, but I'll get to that later. For now I'm just interested in fender placement. ![]() Again, sorry for the lighting, but here you can see just how far they stick out. It's not particularly awful given most heavy hauler or all wheel drive trucks' front ends are often fairly wide, but I'd hoped for better. ![]() And can someone tell me what I did wrong with the install of my 5th wheel? Why is it angling the wrong direction? ![]() |
it looks like you did not put the little v shaped spring on the fith wheel shaft that holds the fith wheel so it leans towards the back
![]() >I've used the inner rim of a Dual on powered steer axles to get the tire tread back under the fender. But, it's a standard width tire, like on your Lesu rims. >You could try taking apart one of your Lesu Duals to see what the inner rim would look like on the steer axle. And can someone tell me what I did wrong with the install of my 5th wheel? Why is it angling the wrong direction? ![]() >All of my stuff run the older Tamiya plastic 5th wheel, and I just epoxy a ball point pen spring to the baseplate up underneath the front of 5th wheel to keep it tilted down.
WILDCAT T&C Jim B. Colorado Springs |
Tommy,
I have a set of Lesu wheels very similar to these. They also have the removable center. Lesu drilled holes around the outside of the hub that allowed me to put a small allen wrench in it. ![]() |
That's a good idea. I'll have to look into it... |
Currently Active Users Viewing This Thread: 20 (0 members and 20 guests) | |
