I'm really getting into the arduino range of stuff, after seeing your post I ordered a starter kit, its awesome! After a couple of hours of head scratching and watching tutorials I created a thermometer with lcd display, the possibilities are endless! My plan now is to make a system to fit in my digger with a small oled display in the cab which shows volts, amps, temp & oil pressure then sends that info to my taranis as telemtry a bit like the brixl system only a fraction of the cost. Running before I can walk I know and the coding is going to be a nightmare but we'll see.... Waiting for oled & volt, amp & pressure sensors to arrive. Stu |
Hi Stuart
You read my mind that is just the route I have thought about taking. Yes there is an Arduino nano in each light tower a relay and a infa red receiver We should compare plans sometime soon we may be of help to each other in this endeavor. I too an new to Arduino and just finding my feet so to speak. I dont have any hydraulic equipment yet however I plan to develop the same type of system for telemetry. many thanks
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
That would be great, I think 2 heads will certainly be better than 1, I can't see it being easy. I have found the code for sending the data via the s-port to a Taranis so thats a start. I'll let you know when my parts arrive and I can start assembling the H/W side of things and look forward to working together on it. Cheers Stu |
