Again, sorry for the lighting, but here you can see just how far they stick out. It's not particularly awful given most heavy hauler or all wheel drive trucks' front ends are often fairly wide, but I'd hoped for better.
![]() >I've used the inner rim of a Dual on powered steer axles to get the tire tread back under the fender. But, it's a standard width tire, like on your Lesu rims. >You could try taking apart one of your Lesu Duals to see what the inner rim would look like on the steer axle. And can someone tell me what I did wrong with the install of my 5th wheel? Why is it angling the wrong direction? ![]() >All of my stuff run the older Tamiya plastic 5th wheel, and I just epoxy a ball point pen spring to the baseplate up underneath the front of 5th wheel to keep it tilted down.
WILDCAT T&C Jim B. Colorado Springs |
Tommy,
I have a set of Lesu wheels very similar to these. They also have the removable center. Lesu drilled holes around the outside of the hub that allowed me to put a small allen wrench in it. ![]() |
That's a good idea. I'll have to look into it... |
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests) | |
