Old 01-06-2011, 10:46 PM
Default Re: Whats Wrong with this GRU?
OH , I thought they're intention was to get a longer screw and bolt everything together at once The screw going through the GRU to the motor from the trans
IHSteve
Old 01-06-2011, 11:32 PM
CustomRCmodels's Avatar
Nothing wrong with it
That’s how these GRU’s are mounted : long enough screws to bolt motor and GRU to the transmission . Otherwise you would have to disassemble the GRU to mount the motor .
And the included pinion-gear goes on the motor-shaft , since upon depending which type you have here ( 2:1 , 3:1 , 4:1 ) the pinions are different sizes .
( I am assuming the pinion-gear you are showing in the photo came with that GRU )
And that the setscrew sticks out doesn’t matter , since that gear which this pinion runs against it is a very thin gear , means you have to do this very precise ( adjustment of the pinion gear on the motor shaft )
(Wild)-Willy
CustomRCmodels
