Old 02-22-2017, 11:07 AM
Tommy R's Avatar
Tommy R Tommy R is offline
Default Re: Peterbilt 6x6 Medium Hauler
It's been bugging me how far out these Lesu wheels sit. Here you can see part of the problem. The recess in the wheel for the hex is a solid 6mm deep. So best case, you're running a pretty wide 6mm hex just to keep the wheels off the axle. Pictured is a 5mm hex with a 1.5mm washer acting as a spacer. In this configuration, just more than half of the tire stuck outside the fenders!
So I decided to take matters into my own hands. I wanted to shoot for the ability to run a narrow 4mm hex to bring the track width inward 2mm per side. I stacked 4mm of washers into the wheel and took out the Dremel and my metal cut off wheel.
Using a steady hand I kept the blade flush to the washers as best I could and proceeded to cut down the recess in the wheel.
After the initial cut, things were functional, but kinda ugly.
I took a flapper wheel to it and it looked much better afterward.
It's hard to capture on "film", but now more than half of the tires are covered by the fenders with a 5mm hex. I have some 4mm hexes on order so we'll see if I can narrow it down just a bit more.
Currently Active Users Viewing This Thread: 20 (0 members and 20 guests)
