Old 02-23-2017, 11:40 PM
Default Re: Eagle Mach JD-98/RC4WD DXR2
Yea, lots of room on the DXR2, no need for external power for lights(runs off 5V from RX), just need a Y splitter if you want to go eagle light system. All channels used on RX. I went off Ch 9 which also had the BEC. Not sure if that will effect voltage or not. Got the heads up it should be good to go from Tang at Eagle so I've got an argument if things go black.
