#1481
Yes, good to get out of the mud!
Avg winter... couple wks of -20's with a couple feet of snow, followed by couple wks just above freezing to nearly melt it all away... 10day ago it snowed 3day straight a couple feet, then the wind blew it around a couple days to make some deep drifts... I didn't go outside for a week, travel through the tunnel out to the shop ![]()
#1482
Hi Joe
Its all looking good on your construction site. Glad your not snowed in anymore cannot be fun, well apart from focusing on your construction projects. ![]() Thanks for posting updates
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#1483
Being storm stayed a week or more doesn't bother me at all, just keep track of the forecast & prepare in advance.
![]() This week's shop project was making a welding table... ![]() ![]() ![]() ![]() The table is 4 x 6 feet, top sheet is 3/16 thickness, I built it for building models. Sitting down to weld I'm steadier now with the tig, welding steel or aluminum is much easier. ![]() Time to start making trls for the 4206. ![]()
#1484
Made a new cage in aluminum for my JD850's rotary screener... the welds aint pretty, but it's not coming apart either
![]() ![]() ![]() ![]() ![]() ![]() ![]() Got a quick-tach coupler for my SA 963 & STahl WA500, plus 4 buckets & the U blade, plus an adapter for the Braeker lock for oem Stahl bucket. Mr Braeker sends out the necessary glue for the stainless steel, but I need to provide my degreaser as that's a hazardous goods that can't be sent in the mail. In the shipment Mr Braeker sends a note that the instructions are provided in PDF on his website & gives a username & password to the buyer to access them. ![]() ![]() ![]() ![]() Mr Braeker's suggestion to use 120 grit to buff the stainless steel with before gluing & painting. ![]() ![]()
#1485
Those attachments look good. Which buckets did you go with? Also how was dealing with him and what kind of price was it to ship to Canada?
#1486
I've been looking at those Braeker kits for awhile for the LR634. Primarily the aluminum bucket with the short "lip/bottom edge?" for more breakout force and having a lighter bucket.
Looking forward to hearing about your experience putting things together, and your tunneling operation.
Youtube username iamaman27 |
#1487
quick coupler for Stahl WA500
quick coupler for Scale Art 963 adapter plate for OEM Stahl bucket leveling bucket L loading bucket XHD Rock Bucket L HD Rock Bucket S HD Abrasion U-Dozer Blade Block Handling Fork Stainless Steel Just sent him an email, he communicates well in english, shipping is cheap! 52,94 euro for 10kg box... shipping out of Europe is dirt cheap compared to anything from the USA... NAFTA is such a farce!
#1488
The tunnel is about done! ...what little is left I'll do in the summer when it's not so bitter cold... just finally feeling better as of today from a two week cold.
#1489
#1490
We don't pay any VAT, that's a european tax, but sometimes (depending on amount) you & I will pay our own pst & gst, although I wasn't charged anything on this parcel from Mr Braeker.
Built the two quick-tach couplers ![]() ![]() ![]() ![]() ![]() ![]() ![]() Then made the fork ![]() ![]() Then tried each quick-tach coupler with the fork to be sure everything works as it should. ![]() ![]() ![]() ![]() ![]() It says in the instructions to not glue anything until all pieces are fitted together... well my clumsy fingers were having quite a time making that happen without pieces falling out of place, so I glued a few pieces in early steps... then discovered at the end why that was a bad idea. ![]() ![]() ![]() The next quick-tach coupler went together much easier & I didn't glue nothing till every piece was in its place. ![]() A top quality product, buy with confidence. ![]() Got some farming to do next couple days, build the buckets on the wkend.
#1491
Those look great. I wonder if the servo will interfere with anything as it seems to stick out a bit. I went on his website he must be using a small ram to lock it in. Looks good either way. Are you gonna be painting or getting them powdercoated?
#1492
I'm sure he's got servo location figured out, these quick-tach couplers have been available for yrs, I've seen many of them in videos from all over the world. The hyd cyl is another option, if you wanna go to the added expense of adding an aux valve. No powder coater nearby. The quick-tack coupler I think I will leave stainless unpainted so the moving parts always move freely, won't paint the fork either. The buckets will be yellow, tape off the quick-tach area so the paint don't cause any problems with coupling.
#1493
Very impressive, gluing metal together, TO COOL ! Thanks for the information Joe..
Greg |
#1494
XHD Rock Bucket L.... about 2 hrs sanding, deburring, cleaning.... then 3hrs so far gluing, just a couple pieces left to fit & glue.
#1495
Wow Joe looks good .curious to see how well the glue stands up..I wonder if there is a way of cleaning the adhesive off if needed ..sure if you wanted you could tig weld some spots .good to see you in the shop making stuff ..Like the new welding table ..will help to keep a good steady hand .
Hows is the weather co-operating .I may have to make another road tip there soon ..I will keep you posted |
#1496
Cheers! |
#1497
That bucket looks mean. I'm sure the glue will hold up well.
#1498
Great project going there. looking forward to see it in action.......crunch crunch video time maybe .........
#1499
Nice Job. It looks like you are on a mission to get those attachments built. Tobias has refined his laser cutting to reduce those burs. That helps a lot with time. Makes it much easier.
As for the questions about the glue holding, I have the same HD Bucket that I use on my 966 sometimes. It is as solid as can be. Loctite 435 is amazing. |
#1500
That's right Neil, in the instructions it says acetone will dissolve the glue, and if the metal glue nozzle blocks up, a quick bit of heat from a lighter will solve that.
![]() The sheets are 1 to 2mm thick, my tig skills need a lot of refining yet before I'd try tig'ing something as polished as these buckets Lou. ![]() ![]() ![]() Bo, the way youtube has changed it's resolution settings, my old gopro looks blurry even with it's hidef setting @ 200mb/minute, my video posting days are pretty well done with just a wireless connection, too slow & too costly! rc13 (forgot your name or maybe you haven't told me, can't remember ![]() Finished up the XHD rock bucket L this morning ![]() ![]() The brass bolt detail is glued in ![]() Moving onto the XHD rock bucket S (this is for the Scale Art 963), the smaller sheet had a lot of splatter from the lazer cutting on one side, chewed up the orbiter sand pad a bit to get it buffed out. Wipe clean/degrease with acetone... twist the parts out... file where needed... start fitting pieces together... maybe by 5pm have another one done ![]() ![]()
