Old 01-07-2011, 10:02 PM
MACK Daddy's Avatar
MACK Daddy MACK Daddy is offline
MACK Daddy is an unknown quantity at this point
Default Re: Whats Wrong with this GRU?
I say again, Bashed? A bit sensitive aren't ya? I never used exclamation marks either in case you missed that part as well
Alfy
Old 01-07-2011, 10:32 PM
ihbuilder's Avatar
Alfy , before this turns into a frenzy , IMHO , this " I bought this from a member on here not knowing about the issue nor was I told " sounds like an accusation ,as dose the the title . If your intent was not to accuse then you could have used a better choice of words . Also ,if there was an issue did you contact the member in private 1st ? then maybe this would have been solved without anyone looking like an azz in public . If contacting the member was fruitless , then this would have been considered a gripe , and would have been moved to the , " get it out of your system section "
no offense ,
IHSteve
