Old 04-03-2017, 11:06 AM
Default Re: Dozer control question.
Am I to presume you're wanting to mix valve with pump so any stick movement activates pump?
Scroll menu on radio, should be a title called Mix.
Mix1 valve ch is 1st -> pump is 2nd, and + - 100 which is first will depend how you wired pump the pump to esc, you want pump to turning correct direction.
Mix2 would be done same way, but the next valve ch.
If you're using right stick on radio for valves, sideways on stick us ail & up/down is elev
