Old 04-04-2017, 11:24 PM
Default Re: 4200XL v1.5 - Replacement Servo Recommendations?
I also seem to recall that if you go Hitec the stock servo horns will not fit. You'll have to cut down one of the horns supplied with the servo to fit the valve block.
Old 09-16-2017, 12:32 PM
arh1a arh1a is offline
arh1a is on a distinguished road
Do you mean cut down the splines in on the servo as they connect directly to the valve block.
What the recommended Hitec servo I should purchase, still the Hitec 5645?
Old 09-20-2017, 07:59 PM
If you go with the hitec it comes with a red 4 arm servo horn. You have to cut it down a bit to fit in the valve head. You'll see once you try and install it.
