Old 04-05-2017, 09:27 PM
Northern Farmer's Avatar
Default Re: servo replacement
Originally Posted by honda3 View Post
Got the servo bolted in and everything is working fine other than the boom moves a tad bit slower in one direction vs the other. The servo doesn't look like it is traveling as far in that direction vs the other way, nothing major. Is that what the endpoints adjust, servo travel?
Yes sir that's what the end points are for. Like Joe said earlier center the servo or else it will act like your's is right now having more travel in one direction vs. the other.
Old 04-06-2017, 09:16 AM
honda3 honda3 is offline
honda3 is on a distinguished road
Yes i centered the servo. I believe the problem is that when i went to put the horn on I had to favor one side or the other. I couldn't slide it on directly centered, it always had a slight tilt either way i put it on. I may try again later today. Thanks for all the help guys.
