Old 04-06-2017, 08:21 PM
Default Re: servo replacement
Some servo horns, if you spin the horn 180 degree on the servo it will split the difference it is out of adjustment... with today's electronic radios, resetting center (listed as sub trim in some radio menus) & epa's is easy peasy anyway, so exact servo placement isn't as fussy as it was once was necessary.
Old 04-06-2017, 10:55 PM
honda3 honda3 is offline
honda3 is on a distinguished road
I spun it 180 degrees and it centered right up. Thanks for all the help guys. The repair was no problem with everyones help and I'm already back to digging. Thanks again.
Old 01-08-2018, 05:11 PM
Helijib Helijib is offline
Helijib is on a distinguished road
Hi there! I’m in the same boat. Need to replace a servo and am wondering what way you we’re able to get to the servos? Pull the pump assembly out or just remove the side of the excavator? Thanks so much!
Also, did you guys end up counting the spine for a direct fit?
