Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Construction Equipment > Construction News
Construction News New kits & accessories offered in the world wide marketplace
Old 04-13-2017, 04:27 PM
Default Re: New Eagle Mach Excavator 1/14
EPA (end point adjustment), that might be listed as servo adjustment in your radio menu. What % is the motor running at now? Lower it too much & the motor will behave a bit erratic & heat up esc... for lower hyd speed movement you could lower the EPA on your valve chs so it takes more stick throw to open the valve or use 2s lipo, but a lower voltage will slow down your track speed too.
Old 04-13-2017, 04:34 PM
Northern Farmer's Avatar
Try contacting Mario or DiggingwithMartin on youtube they will help you tune your machine right. Channel 5 is for the pump.
