Video quality not too bad, you're outside with lots of light, did you save vid on Ipad "for email" setting?
If you had yourself a real track hoe you wouldn't feel the need to cheat with life size equipment ![]() Found Mr Nutters, he's enjoying ice cream cones down south ![]() https://s.theweathernetwork.com/vide...312993038001_2
![]() And yes I really should start thinking about a new hoe,,, a lot of things are starting to wear, this will be the third swing motor, still works but a lot of play, track motors just don't have the strength. Or some more modifications. Probably go with that when something completely fails. And yes a little extra help was outsourced for the ground cover removal to start stripping the topsoil down to concrete wall grade from the old silo. Really the only reason I did use the tiller was to save some wear n tear on the lil' company assets. I did use the ripper to rip a 6x6' area. Sod ripping is pretty tough on the dozer ![]() ![]() And I wish I would have had taken more videos when we had mr nutters in the house. Thanks for sharing joe ![]()
Currently Active Users Viewing This Thread: 28 (0 members and 28 guests) | |
