Old 05-07-2017, 12:58 PM
trucker n's Avatar
Default Re: servontaut a replacment for tamiya mfu?
I had the bier usm-2 and loved it about to get another there is so much u can program with it
Old 05-10-2017, 12:23 PM
Grip_Runner Grip_Runner is offline
Grip_Runner is on a distinguished road
Brel I have been looking at the servonaut unit and it looks fairly easy to wire up if my presumption is correct. if I understand it right you have to positive terminals to connect to and the negative feed is plumbed into the appropriate terminal i.e. one wire from one of the common positive's to the led and the negative from the led to the brake light terminal for example or have I got it wrong?
Old 05-17-2017, 07:07 PM
Brel's Avatar
Brel Brel is offline
yes the red positive is common to all the lights and the negative is the switch wire to turn the lights on and off
I commoned all the red wires nearer the lights and then joined the brake lights together and ran that feed down the chassis, I did this for all the lights on the truck so that you have one single commoned red and one negagtive switch wire for each pair of rear lights except the indicators (turn signal), did the front lights in the same way apart from the verkerk lights which have to be wired up according to their instructions
