Old 05-16-2017, 10:43 PM
honda3 honda3 is offline
honda3 is on a distinguished road
Default Re: eagle mach parts
Thanks for the help Ken, whats the best way to purge the system?
Old 05-17-2017, 02:54 AM
Rimrock Rimrock is offline
Air in the cylinder;
Put the hose(s) connected to the cylinder, directly into a tank/container, containing the correct grade of oil, and drag the piston in and out some times until all air is out, and the cylinder is fully filled with oil.
Generally check all fittings/hoses, that air is not let into the system
With magom, be sure to use proper grade of oil, very thin. Magom original oil. (grade 15 possible, but not known exactly what they use)
