Old 05-17-2017, 06:29 AM
Rimrock Rimrock is offline
Default Re: eagle mach parts
I've not ordered parts for the RC4WD machines directly from the producer, Eagle /mr Tang, but it's a possibility I guess, even if one have not bought the machine from them in the first place. As a dealer, I get a better deal purchasing the machines via RC4WD, than directly with Eagle, so I prefer getting everything through them. but as private customer, might be a difference. A customer had some gears broken in one of the track motors of his 360L, and we got the via RC4WD customer service in a couple of weeks. Shipped directly from the producer in China, Eagle. I guess I would advice to get parts through where you bought the machine, RC4wd, or your local dealer, if not bought directly from Eagle. RC4WD can get the spare parts on needs buy contacting them, picture helps a lot. They just lists/ keep in stock a few of the most common in their web shop. E.g cylinder gaskets is a typical thing that will wear, especially the cylinder rod seal, same for any brand of machine. Starts leaking oil at the rod seal. Often just enough to change that particular seal, it's a standard 1.5mm thicknes o-ring, 7-8 mm inner diameter, avaiable at ebay and so on. Or optionally purchase a complete gasket kit, as rc4wd typically will offer
