Old 05-21-2017, 02:12 PM
Default Re: O&K Damitz RH6.6 Big OilPump 750ml
Frank, congrats on your awesome machine!
I would first find out which pump you exactly have already. Second, make sure the servo for the track were opening up the valve completely. I would check that out. Also make sure you are using the correct weight hydraulic fluid.
Old 05-21-2017, 06:01 PM
trucker1970's Avatar
trucker1970 trucker1970 is offline
trucker1970 is on a distinguished road
Thank you! I am using the Scaleart oil the builder/modeller/whatever he is sent me and had in the machine. He sent me a new bottle. I have to assume he knows what he's doing. The Damitz has little tabs on top that makes it easy to see where the servo is at and they are both opening 100% I will check and see what the current pump is when I get time. Thanks
File Type: jpg IMG_9576.jpg (157 Bytes, 83 views)
