Did get the last connection done to fuel tank (orig. hydr tank) and for upper oil tank (normaly fuel tank) incl fuel caps. Why swapping the tanks? Need all volume to oil system, the smaller one will do for Honda engine.
Next for hydr system is to get all connections on adapter to filter glued or welded togheter. Still missing is the 2 front blade cylinders, have the tube but lacking rods. then it should be done, I hope. Tubing from fuel caps is breating lines that will be connected to lines inside ROPS. ![]() The battery box was redone, now sliding forward with hidden box that will have reciever and battery. Brackets between ROPS and Cab foundation added. ![]() |
Nice metal work. It is looking really good.
Tags |
1/5.6, big scale, cat, d8r, dozer |
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
