Old 06-26-2017, 10:20 PM
Default Re: Tamiya gearboxes
The 260 is a bigger, more powerful motor than the 130. Most of their gearboxes come with wimpy 3v blue endbell motors that burn out pretty quick at 7.2v, so plan on buying a new set. Also get a stack of shims so you can get the gear teeth to overlap properly, or you'll lose ability to handle torque due to gears sliding on the shafts.
If you've got the space, the bigger one has the power and is probably more durable.
I haven't played with either of the dual motor gearboxes yet i'm still collecting parts for a Bruder build, and i'm not sure what a 963 is.
