Old 07-22-2017, 02:02 AM
Default Re: Issue with my Grand Hauler... PLEASE HELP
Disconnect everything from the rx.
Connect esc, try running. Connect a servo, try running. Connect another, try running... eventually something should cause it to act up, remove it again and see if it works ok.
Is the antenna ok and away from the motor?
Does motor have caps installed?
