Old 01-09-2011, 09:05 PM
Default Re: radio input
Hold on a second here. Yes, you can select a different model on the fly, from the radio's memory, but any receiver, in a model, left 'on', would still be receiving a signal. In effect, you'd be controlling more then one model at a time, but the programming of each model would have them all doing something different then expected (except for the one that is currently pulled up on the radio). I.E. servos may be reversed, on certain channels, end point adjustments would be off, ect. Just because you switch the current model, in the model memory, does not mean the other models will go into stand-by mode. If any receiver is bound to the tramsmitter, it will continue to do whatever the radio signal says it should.
You are correct Nathan but there is a radio that will do that. The Spectrum radios have model match and only the model selected on the radio will accept input. I like this feature with my crawlers you can turn them all on and just switch between them and the others just sit there no glitching or movement what so ever.
Travis
Old 01-09-2011, 09:20 PM
Travis
Really? That's very handy then! Only Spektrum has this feature then?
Old 01-09-2011, 09:50 PM
woodhog's Avatar
woodhog woodhog is offline
thanks for the input guys on a radio like the airtronics how are you controlling track movement or on any radio for that matter .thanks for input
