Old 08-10-2017, 05:06 AM
Default Bruder small Cat conversion
Tonight, I started a Conversion of the small caterpillar, D4 I think it is.
Old 08-10-2017, 05:14 AM
Default Re: Bruder small Cat conversion
Once my Email quits lagging, & I can get them to show up in my INBOX, so I can upload them to flilcker, I'll post up a few pics.
I CAN'T take credit for the inspiration on this build. Jug has done it & posted it on his YouTube page. I liked the idea. I wanted to use Micro Servo's for it, but was having a problem finding a part that would connect the micro servo to the track sprockets. Since I couldn't source the parts I wanted, I ran with his idea. I will deviating slightly from his build in the way the sprockets mount to the motor......That is, once the parts FINALLY arrive on the SLOW boat from China.
Old 08-10-2017, 05:26 AM
FINALLY, they showed up in my Email. Here's a few pics of the build so far
20170809_234213 by Anthony Kalnoski, on Flickr
20170809_234244 by Anthony Kalnoski, on Flickr
Old 08-10-2017, 05:28 AM
20170809_234155 by Anthony Kalnoski, on Flickr
Old 08-11-2017, 02:26 PM
frizzen frizzen is online now
I think thats a D5, and looks like a good start.
You may want to shim the gearbox shafts, some have too much play and the gear mesh is inconsistant.
Old 08-11-2017, 09:47 PM
I wish I would have saw that BEFORE I did what I done on Thursday morning. Thinking I would be slick, & try & dust/dirt proof the gearbox a bit, I did this little mod.
20170810_051457 by Anthony Kalnoski, on Flickr
20170810_051447 by Anthony Kalnoski, on Flickr
In addition to dirt proofing it a bit, my thought was, it'd give the inner workings a SAFE place to lay, WITHOUT risk of getting caught in the gearbox. In hindsight, I'm sure I SHOULD have completed the build & tested it prior to doing it.
Old 08-11-2017, 09:48 PM
Those are the only pics I have of it. The glue has since dried, & the clamps are removed.
Old 08-14-2017, 09:55 AM
Rain delays this weekend at work, left me with some spare time this weekend. I did a bit on the Cat.
Added a bit of weight, about 6OZ to it, mounted the blade servo, & affixed the track sprockets to the Tamiya gearbox.
20170813_013849 by Anthony Kalnoski, on Flickr
20170813_034818 by Anthony Kalnoski, on Flickr
The bolts I had that were lengthy enough were WAY TOO LONG. I used them, cut them off after installation, & filed them flat with the adapter.
20170813_035955 by Anthony Kalnoski, on Flickr
Since I had the gloves on to work with the epoxy, I decided to drill a hole in a fishing weight. It was an 8OZ weight, with a bit trimmed off of it. I guestimate it's about 6OZ left on it.
20170813_032420 by Anthony Kalnoski, on Flickr
The sides of the dozer modified so the redneck lifting mechanism for the blade can do it's thing. YEAH, I KNOW, I went a bit overboard hogging out the holes in it. I had some leftover scraps of plastic laying around. I glued them into the excess opening. I forgot to take snaps of it.
20170814_023921 by Anthony Kalnoski, on Flickr
The metal gear micro servo installed
20170814_030713 by Anthony Kalnoski, on Flickr
Old 08-14-2017, 10:00 AM
Just a few more mods to do on the tracks, & then it'll be time to test it out. I know being plastic if WON't be durable, or powerful enough to push much of anything, but it'll still be fun.
Old 08-14-2017, 10:03 AM
A quick note about the lead weight. If you plan to drill a fishing weight, as I did, & it's pure lead, be prepared for a LOT of work. I'd get about 2 seconds of the drill working in the lead, then I'd have to spend 10-25 seconds cleaning the drill bit. The lead clogs up the bits. It DOESN'T spit out in ribbons like other metals do.
Old 08-14-2017, 01:50 PM
Looks like it's coming along well.
Watch some videos, bruder conversions are pretty capible, even though it's plastic.
Lead likes some thin lube and a slow feed rate so it spits little flakes off the bit, and pulling out to clear chips a lot.
Old 08-14-2017, 10:05 PM
honda3 honda3 is offline
honda3 is on a distinguished road
I just received a d5 conversion from small haul on youtube. This is one bad little dude, not only will it push dirt but it will also cut in. It is a very capable machine and affordable.
Old 08-14-2017, 10:36 PM
I'm glad to hear that. I was worried that being plastic it may not do so well.
Old 08-15-2017, 06:03 AM
I've many questions about yours. Are the tracks still the stock Bruder kind? Is the cab interior still in it? What size battery pack is it running? Is/was any weight(s) added to it when it was converted?
Old 08-15-2017, 07:22 AM
Yes tracks are stock bruder, they actually provide way more traction than i thought they would. Cab interior is still in, 2300 mah nimh pack, It was stuffed with as much weight as he could fit, It weighs around 5 pounds.
Old 08-15-2017, 09:06 AM
Do you have pictures of how & where the battery mounts in it? I'm struggling trying to figure out how to put the battery pack in it, while including the cab interior.
Old 08-15-2017, 03:00 PM
I don't know how it is mounted inside it came RTR, And i probably wont take it apart until I have too. Look up "small haul" on youtube, he has a bunch of videos and I'm sure you can find what you need.
Old 08-18-2017, 11:23 AM
After looking at a few of his vids, I found the info for his builds. There's an internal RECHARGEABLE battery pack in his I LIKE that idea.
Old 08-18-2017, 11:31 AM
After working Thursday, & then finding out we're working Friday NIGHT, I stayed up all night to get my self acquainted with night shift AGAIN! I had a LOT of time to work on the littel dozer.
I found a PROBLEM with where I mounted the blade control rod. I SHOULD have ended the bolt between the 2 side of the blade arm, & NOT ran completly through it.
20170817_225951 by Anthony Kalnoski, on Flickr
It SHOULD have ended where the knife blade is, & has since been re-located.
20170817_225345 by Anthony Kalnoski, on Flickr
I cemented the blade pivots where the knife blade is, to prevent it from moving while working
20170817_225400 by Anthony Kalnoski, on Flickr
Each drive sprocket got TEN screws placed into them between every OTHER tooth. 20170817_205810 by Anthony Kalnoski, on Flickr
NOTE: DON'T do like I did! Before I reinstalled EVERYTHING onto the tracks, I adjusted the slack in the track by lengthening the distance the screws stuck out form the sprocket. Once I re-assembled the track guides, the tracks were too tight.
Old 08-18-2017, 11:37 AM
I somewhat flattened a 20Ooz teardrop shaped fishing weight. I plan to trim it to shape, & place it in the dozer for more added weigh. I still have bugs to work out with it. Once my Email quits lagging, I'll post the vid of it. The video ISN'T a very long video, & doesn't show the quirks I have yet to work out with this little dozer.
