Old 08-23-2017, 10:05 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Eagle Machinery Dozer track pin problems
Let's see how this works, let me know if you have trouble with the photo links.
https://flic.kr/p/WLyL7k
https://flic.kr/p/WLyLgP
(Does anyone know if there is a way to make this a thumbnail instead of a link?)
I think you can see the three brass tube pins in the center adjoining links? On my Dozer the pins can NOT be much longer than the outside holes on the link or they would catch on the frame. Since my Dozer is only 1:16 scale I am a bit smaller than yours and the pin size may not be the same. For me, there are two advantages/observations:
The brass tube is easier to work with that steel, it seems to be more than strong enough since the pins are so short and the diameter is small. I can clip the brass tube with wire nipers, And, I have busted out the holes when over stressed while using steel. The brass may be a bit easier on the tracks than steel, I would rather install a new brass tube pin that replace a track.
Jim
Old 08-25-2017, 06:32 PM
Jim
Yes sir, there's a way. When you click on the image you wish to share, there should be something that resembles a RIGHT TURN ARROW, click it. then select the option for the (BBCode IF I REMEMBER RIGHT, it's some kinda code thingy), & select MEDIUM size for the photo size option. Copy that code link it produces, & paste that link into your post here. I hope this helps. I'm not too technologically knowledgeable.
Old 08-29-2017, 02:49 AM
Rimrock Rimrock is offline
It happens that these kind of pins come out, more or less. I just put a bit 'super glue', or instant glue what ever on those pins. Not bother to change all bolts to e-clips type.
Soyland Industrier
Old 08-29-2017, 11:42 AM
trucker1970's Avatar
trucker1970 trucker1970 is offline
trucker1970 is on a distinguished road
**UPDATE** OK so blue locktite then superglue on one and blue locktite only on the other and at a quck glance looks like one pin on the locktite only track was sticking out just a bit so who knows maybe I missed that one. I ran it for about a half hour of actual use it sat mostly while I loaded my 8x8 with the excavator. I need to put it up on the work bench and do a closer inspection and make sure it's only the one. THANKS for all the messages I'm glad it wasn't just me!
Old 09-07-2017, 04:47 PM
ariari ariari is offline
ariari is on a distinguished road
I used also blue loctite and no problems yet... I read that this red loctite needs heat and force to remove so I didn't want to use that stuff.
I have some excavator tracks which I think is also from eagle mach (ordered from aliexpress) 50mm width and those will fit in the dozer also.
