Old 09-15-2017, 10:56 PM
Backlash Backlash is offline
Backlash is on a distinguished road
Default Re: DXE
Originally Posted by ad2tude View Post
Thanks for the help
Seriously? No reply in a day and a half and you get all hurt?
I'm assuming that you're talking about the Spektrum DXE?? http://www.spektrumrc.com/Products/D...ProdId=SPM1000
I can see no reason why the Specktrum DXE will not be suitable to operate a basic truck...
HOWEVER, I'm not sure if it will be suitable if you plan to use a Tamiya MFC-01/03 multifunction unit, as the MFC-01/03 uses the (analog) trims on the radio to access the extra functions like turning the lights on/off and the DXE appears to have digital trims...
You can use a computerized radio such as the Spektrum DX6 that has digital trims with the MFC-01/03 by programming the dual rate function of the radio to activate the trims..
