Old 09-27-2017, 12:07 AM
Default Re: Liebherr LR634 Track Loader HYDRAULICS
While I CAN'T speak firsthand for the MagomHRC kit for that model, I can speak of their OTHER kits/parts. I tried a Bruder D11 conversion, & bought parts from MagomHRC. I bought the motor mounts, & the drive adapter to mount the Bruder Cat sprocket to the motor. The Motor mount, the BIGGEST motor in diameter I know of (The ones like the Tamiya trucks come stock with) the mounting holes were to close together to bolt to it. The adapter for the drive sprockets, the shaft on the largest motors I have easily access to, (Gear reduction motors) DIDN'T have a large enough shaft to fill the hole in the adapter. IF you go with MagomHRC, do yourself a favor, & make sure you buy a COMPLETE kit with EVERYTHING you'd need for the swap. That's my two cents on Magom's stuff. It looks like great quality stuff, but it's not easy to purchase the key components from them, & buy the other things needed elsewhere to complete the build.
Old 09-27-2017, 12:23 PM
FabOne's Avatar
FabOne FabOne is offline
FabOne is on a distinguished road
THANKS for the come back!
Yea, I'd buy the entire hydraulics kit for the LR 634.
-Terry
FabOne
NW Ohio
