Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Scale Buildings, Warehouses and Structures.
Scale Buildings, Warehouses and Structures. If you have buildings and other structures that you have built to use with your Rc's here is your place to share them.
Old 10-20-2017, 03:26 PM
Default Re: Wanco vertical mast arrow board
It's not that bad, just go 1 connection at a time. It would look less complicated if i'd spent a bit longer doing hookups. Or color coded things better.
Make the board, put all the leds of a bus in facing same way so you can connect anode to anode, cathode to cathode. This way you really only have to insulate where it has anything crossing a bus.
All the buses are made in parallel. The arrow arms probably don't need the line to 2nd led opposite if you want to get lazy and save a few connections, but the real ones drop out the 2nd column center row light on the arrow side, this was easiest way i could think of.
Power comes off a 9v battery into the 555, the chip can be a little confusing, then chip output hits the center bus with ground, and power has a drop resistor. If you prefer solid, don't even worry about blinky circuit.
If you have a broken toy or old packaging from something that had an LED blinky light, you can save even more work by reusing the circuit.
I liked the 15 light board, it's most of what's here, and it's electrically easy to get the 3 patterns i usually see.. Unless you're feeling like a badass don't do the 25 led board that can do 12 patterns
This project started because a friend of mine ordered a bunch of components off ebay, gave me some, and i was trying to figure out how to use them. Got stuck in construction traffic...
