Old 11-01-2017, 06:04 PM
Mustang46555 Mustang46555 is offline
Mustang46555 is on a distinguished road
Default Re: 6x6 Peterbilt 379 tractor build
Darwin,
I have used two Shapeways cabs. Yes you can see faint lines from the 3d printing process and they can be somewhat grainy. With that said, use a good "high build" primer, multiple coats, lots of patience and fine sandpaper and they can be made smooth, but don't go into it expecting a smooth injection molded surface right out of the box. It will take "sweat equity" to achieve a glossy finish. But it can be done and the results are well worth the effort.
Old 11-01-2017, 06:16 PM
Coastway Trailers Coastway Trailers is offline
Coastway Trailers is on a distinguished road
Originally Posted by Mustang46555 View Post
Darwin,
Thanks for the reply, I appreciate it. So glue will stick to it also, so a person can modify it a bit? Any issues with paint sticking to it? I usually use automotive primers so hopefully that would work on this stuff to.
Thanks,
Darwin
