Old 11-01-2017, 07:29 PM
Coastway Trailers Coastway Trailers is offline
Coastway Trailers is on a distinguished road
Default Re: 6x6 Peterbilt 379 tractor build
Originally Posted by Mustang46555 View Post
CA sticks just fine for a glue. I've used both automotive primers as well as Tamiya primer. Both worked well. As with any new surface, test your desired paint in a small out of view spot for compatibility. I've also used automotive spot putty with good results.
One trait of 3d printed material in thin sections is for paint to bleed through to the other side. Once primed and sealed it is no longer an issue. I have not seen it on either cab but it is a possibility to be aware of.
Thanks, that helps out. I just may give it a try.
Darwin
Old 11-02-2017, 03:41 AM
Rimrock Rimrock is offline
I personally go for a primer especially developed for plastics, or etch primer, as first coat. The shapeways prints have a corned surface, maybe it helps standard automotive primer to stick better, compared to on a smooth plastic surface. I avoid standard metal primer on the prints myself, but if someone have good experience with it, that's great, just stick with it.
Soyland Industrier
