Thanks for reply, I asked because the lighting in your photo made the hubs look alot like some rims I tried 3d printing some time ago. Was going to ask you how much effort it was to smooth them out as much as it appeared you had. I really like your idea though of mixing the hub portion of a standard wheel with the machined pvc. I think I'm going to try that just using 3D printed hubs. If nothing else will save a lot of support material and make cleanup much easier.
Hey Ya All ! The Wheels Tutorial is under production.........Jeez it's a lot of work to make it worth to show. Please have patient and it will pop up here right in front of your eyes
![]() [IMG] ![]() Teaser In Chrome and Crazy Wide ![]() Last edited by Bo Wallen; 04-23-2018 at 10:31 AM. |
Short update of the fix for the broken trailer axle.
I've got some time to make the sleeve for all trailer axles that use std.axle. From now on i go full metal axles. [IMG] ![]() [IMG] ![]() The Tutorial of wide rims is still under production.........more time needed and a few tools too. |
Production run done. Check ;o)
Now Installing them sleeves. [IMG] ![]() [IMG] ![]() Forgot to say........400% stronger/heavier load with da fix.......I'll take that any day ! Last edited by Bo Wallen; 04-23-2018 at 10:32 AM. |
How do you like the little chop saw? Is that one of the Micro-Mark ones? I've got a project I'm planning that is going to call for a ton of brass cutting and I'm thinking of getting one.
How to avoid cutting fingers in a 12 inch chopsaw this is great for small pieces. A few things to think of. 1. weak motor stall easy. Use cutting oil and it cut easy. 2. sawblade get clogged easy. Use more cutting oil. Problem solved. 3. Take your time and don't overcharge the sucker...... job done. 4. Did i mentioned screw it to a sturdy surface.........otherwise you will mess up your work of art. Have Fun. Is it the best saw out there ??? Probably NOT but for $34.99 i will say it's doing a lot of cutting. Last edited by Bo Wallen; 12-06-2017 at 08:43 PM. |
Kerst |
