Old 11-21-2017, 11:22 AM
Efroeh Efroeh is offline
Default Re: ADT build
Originally Posted by SteinHDan View Post
Very nice build!
I'm looking forward to the updates with a lot of anticipation!
For some while I've been pondering with an ADT build myself, but it likely won't happen for real for a few years more.
Anyways, I was playing with the idea of using gas springs for the bed lift (very cheap) and then a powerful gear motor to pull it back down again with a wire rope. I was thinking something like 2x15kg gas springs 150mm stroke:
- https://www.aliexpress.com/item/free...296134474.html
and this gear motor:
- https://www.ebay.com/itm/231911256302
And then some wire rope around 1mm thickness:
- https://www.ebay.com/itm/222599707119
There is very little extra room to go on for the cylinder with the very long stroke they have to have to get a proper angle on the bed when tipping. I don't think an inline electric motor (like in the electric actuators) will enable you to get a cylinder that mounts in the normal positions or will provide the normal tipping angle for the bed.
Best regards,
Stein :-)
That's a good idea for lifting the box. I'm gonna try the actuators from actuonix first as I have a few sitting around.
Also I think I'm gonna change my mind with steering and go to a large scale servo. The gear motor would be good but can't get it to auto center and be harder to control I think.
