Old 11-27-2017, 01:44 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: Skeeters contracting services
Machine would be fine for light milling in plastic only or engraving. I would not use it for much of anything other than plastic. No telling what kind of bearings are in it. Milling machines need bearings that can take a side load. Engravers and drill press' do not have bearings made for side loading. That is why a drill press will start making oval holes besides bad drill bits.
I would get a regular milling machine and convert to CNC. Need to go slow and learn process as you go. I speak from 30 years of machining experience- both manual and CNC.
LYNN
Old 11-27-2017, 03:24 AM
Thank-you, sir for the info. I will NOT be acquiring that machine!
I plan to take it slow, starting with a small machine, & eventually, HOPEFULLY get into bigger machines.
