Old 12-04-2017, 07:37 AM
Mikem Mikem is offline
Default Re: Bucyrus Erie crane truck
Hi Shawn what are planning on using for a swivel on the crane house
Old 12-04-2017, 12:37 PM
Krewmember's Avatar
The plan is to get the swing mechanism as close to the real machine as I can. So I'm going to machine a custom swing ring and cut internal gear teeth in to it just like the deal.
Here is a diagram of what I have been able design based on what information I have.
The ring will be mounted to a base by bolt holes tapped in the ring, the base will have the bearings for a central shaft that will be mounted to the crane frame. The frame will have rollers that go inside the race in the ring, like this.
Shawn
Old 12-04-2017, 01:32 PM
This is interesting the ring mounts to the truck then the wheels are mounted to the crane and support the weight of the crane ? Is there a center pivot ?
Old 12-04-2017, 01:40 PM
Krewmember's Avatar
Yes, there is central shaft that runs through the crane base to the ring base
Shawn
