Old 12-05-2017, 03:19 PM
Krewmember's Avatar
Default Re: Bucyrus Erie crane truck
That makes sense. Thanks for clarifying that.
Old 12-05-2017, 04:19 PM
Mikem Mikem is offline
So the rollers need enough clearance to roll but not to tight not to loose . Hmmmm
Old 12-05-2017, 04:45 PM
Yes. When we adjusted hook rollers, we'd lay the boom straight out (sometimes with weight on it) to tilt house forward, then measure clearance at top of front rollers and at bottom of rear rollers. Since rollers are tapered, adding or removing shaft shims would push them toward or let them pull away from the center shaft, altering the clearance between roller and circle flange.
Old 12-05-2017, 05:09 PM
Ok now just have to build that in 1/14 scale . Thanks Ken
