Production run done. Check ;o)
Now Installing them sleeves. [IMG] ![]() [IMG] ![]() Forgot to say........400% stronger/heavier load with da fix.......I'll take that any day ! Last edited by Bo Wallen; 04-23-2018 at 10:32 AM. |
How do you like the little chop saw? Is that one of the Micro-Mark ones? I've got a project I'm planning that is going to call for a ton of brass cutting and I'm thinking of getting one.
How to avoid cutting fingers in a 12 inch chopsaw this is great for small pieces. A few things to think of. 1. weak motor stall easy. Use cutting oil and it cut easy. 2. sawblade get clogged easy. Use more cutting oil. Problem solved. 3. Take your time and don't overcharge the sucker...... job done. 4. Did i mentioned screw it to a sturdy surface.........otherwise you will mess up your work of art. Have Fun. Is it the best saw out there ??? Probably NOT but for $34.99 i will say it's doing a lot of cutting. Last edited by Bo Wallen; 12-06-2017 at 08:43 PM. |
Thanks alot for info Bo. Got two harbor freight stores near me so I'm going shopping tomorrow.
Kerst |
Picked one up today. Does indeed work well and I'm pleased with it. Only issue is that the blade clamp screw keeps working loose. Nothing that a drop of loctite probably can't fix. Great little machine for less than half the cost of the one I was looking at. Thanks guys.
Zabco. Kerst. Yes nothing is like affordable cool tools.....gives some space for the other bling parts we really need. So i was so impressed with this little bugger....... I went and picked up a couple more. I'm building a souped up table saw with sliding table and bigger motor....... ![]() |
Tamuder Shop Truck Deluxe.
[IMG] ![]() While waiting for tools and other stuff for the Wheel tutorial. I'm finishing this one. Don't look to close......the wood is just for sizing up toolbox..... Last edited by Bo Wallen; 04-23-2018 at 10:32 AM. |
