#321
AWESOME! It'll be a GREATtutorial when it's done. Nice job thinking outside the box on that. I wouldn't have thought
#322
Thanks for reply, I asked because the lighting in your photo made the hubs look alot like some rims I tried 3d printing some time ago. Was going to ask you how much effort it was to smooth them out as much as it appeared you had. I really like your idea though of mixing the hub portion of a standard wheel with the machined pvc. I think I'm going to try that just using 3D printed hubs. If nothing else will save a lot of support material and make cleanup much easier.
#323
Hey Ya All ! The Wheels Tutorial is under production.........Jeez it's a lot of work to make it worth to show. Please have patient and it will pop up here right in front of your eyes
![]() [IMG] ![]() Teaser In Chrome and Crazy Wide ![]() Last edited by Bo Wallen; 04-23-2018 at 10:31 AM. |
#325
Short update of the fix for the broken trailer axle.
I've got some time to make the sleeve for all trailer axles that use std.axle. From now on i go full metal axles. [IMG] ![]() [IMG] ![]() The Tutorial of wide rims is still under production.........more time needed and a few tools too. |
#326
Production run done. Check ;o)
Now Installing them sleeves. [IMG] ![]() [IMG] ![]() Forgot to say........400% stronger/heavier load with da fix.......I'll take that any day ! Last edited by Bo Wallen; 04-23-2018 at 10:32 AM. |
#327
How do you like the little chop saw? Is that one of the Micro-Mark ones? I've got a project I'm planning that is going to call for a ton of brass cutting and I'm thinking of getting one.
#328
How to avoid cutting fingers in a 12 inch chopsaw this is great for small pieces. A few things to think of. 1. weak motor stall easy. Use cutting oil and it cut easy. 2. sawblade get clogged easy. Use more cutting oil. Problem solved. 3. Take your time and don't overcharge the sucker...... job done. 4. Did i mentioned screw it to a sturdy surface.........otherwise you will mess up your work of art. Have Fun. Is it the best saw out there ??? Probably NOT but for $34.99 i will say it's doing a lot of cutting. Last edited by Bo Wallen; 12-06-2017 at 08:43 PM. |
#329
Thanks alot for info Bo. Got two harbor freight stores near me so I'm going shopping tomorrow.
#330
Kerst |
#331
Still following and salivating over the progress.
#332
Picked one up today. Does indeed work well and I'm pleased with it. Only issue is that the blade clamp screw keeps working loose. Nothing that a drop of loctite probably can't fix. Great little machine for less than half the cost of the one I was looking at. Thanks guys.
#333
Zabco. Kerst. Yes nothing is like affordable cool tools.....gives some space for the other bling parts we really need. So i was so impressed with this little bugger....... I went and picked up a couple more. I'm building a souped up table saw with sliding table and bigger motor....... ![]() |
#334
Tamuder Shop Truck Deluxe.
[IMG] ![]() While waiting for tools and other stuff for the Wheel tutorial. I'm finishing this one. Don't look to close......the wood is just for sizing up toolbox..... Last edited by Bo Wallen; 04-23-2018 at 10:32 AM. |
#335
Nice little truck
#336
Nice work. I was just looking at one of those little chop saws and was thinking about getting one.
#337
![]() ![]() Cabin Fever is getting closer and closer. Trying to get ready ![]() [IMG] ![]() Last edited by Bo Wallen; 04-23-2018 at 10:34 AM. |
#338
Sweet company logo
#339
Thank You Brandon. Michelle at Krawler Konceptz Is so fantastic to deal with, and the quality is over the top ! She is making the Canadian plates now for me.....
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests) | |
