Old 12-13-2017, 09:21 AM
Default Re: Bucyrus Erie crane truck
I've posted this in the past. Is this of any help? I have more if needed.
Old 12-13-2017, 03:49 PM
Mikem Mikem is offline
Yes I have seen these , but I’m looking for more dimensions. And I thought Jared had a personal drawing of the turntable . Reading these engineer drawing is not for the faint of heart . Thanks Mike
Old 12-13-2017, 05:01 PM
Usually I enlarge or reduce these drawings to fit my use. The design is pretty much the same throughout the line of these machines.
I may be able to dig a little deeper in my books and find more on those rollers.
Old 12-14-2017, 12:21 AM
Krewmember's Avatar
Krewmember Krewmember is offline
Krewmember is on a distinguished road
I took this drawing and used the measurements at the top and did some quick scaling to get the dimension for the swing ring. It should be accurate if the drawing is to scale, all you have to do is use a scale calculator to get the dimension for your model. I'm modeling to 1/14 scale, so 55 3/8" in 1/14 scale is 3.96"
I hope this helps you.
Shawn
Old 12-14-2017, 06:30 AM
Thanks for this it does help . I was using my guesstimated size of 4 inches , so that was close to 3.96.
Old 12-15-2017, 06:22 PM
Krewmember's Avatar
A small bit of progress on the crane. I made this service hatch, I don't know what it's supposed access on the real machine but it should come in handy to access the winch motors or a battery.
Shawn
