Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
The machine you referenced is called a 'Jackscrew mechanism'. You can use all-thread and nuts, or the nicer version uses Acme rod with Acme nuts.
Also a forum sponsor Actuonix makes several plug and play linear actuators, that can be run as either a linear servo that self centers or an actuator that holds position. It would be cheaper than hydro. They even have built in micro switches at travel limit.
Greg,
Here is a link to my dump truck video. I used a small motor to turn the threaded rod which turns inside a section of delrin that I threaded to match the rod. https://youtu.be/b-pTdpjsn_M Jim |
Hi Jim, Thank you for the link, your dump truck looks great !....and yes another option to think about for lifting my ride ![]() All the best Greg |
That's handy to know as I did look into some linear actuators some time back but at the time couldn't source one the right spec...I'll have to have a look at those if the hydraulic method doesn't work out. All the best, Greg ![]() |
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests) | |
