Hi Dean,
here you can activate the digital mode: ![]()
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Hi,
another hint to your indicators. as shown above you can activate the indocators by moving the steering. I'm using this in combination with an alternative configuration. I'm using the EKMFA to activate the wanted functions. ![]() In addition I configure the indicator to be switched off via the steering ![]() Now I do have 2 possible ways touse the indicator. 1. I can activate the indicator a time before I make the turn by using the EKMFA. It will be automatically turned off if I steer back. 2. I let the Prop#2 settings activate and deactivate the indicator Both options can be configured together, they do not exclude each other.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
