Old 01-08-2018, 08:56 PM
Default Re: RC4WD Dozer, modifications, upgrades, settings.
I'm in that boat as well Yard with regard to the pump motor on/off with functions. Also I'm using the stock "Radio Link AT9" TX with 2 mixes and no problem Either way you should be able to do 2 mix's easily, not sure why you can only have one mix? Did you get yours new or used? Again this is with the stock 2 ESC's for the drive motors. With a Sabertooth your combing 2 ESC's into one which makes it somewhat easier.
