Old 01-10-2018, 06:15 PM
thebigo thebigo is offline
Default Re: 4200XL v1.5 - Replacement Servo Recommendations?
Originally Posted by Helijib View Post
Hi guys,
In order to get to the servos are you guys pulling the metal side of the excavator body off by unscrewing the screws or are you pulling the pump mechanism off the floor of the frame and getting the servos off that way. Seems like both ways aren’t very good as I think of you pull that safe off the paint is going to chip where the plate meets the other body edges.
Thanks!!!
Do not take the body side off, your paint will be screwed up, just take the one screw out or two screws on the bottom of the excavator where the valves are located, mine has one, then turn it and pull your servos off.
David
Old 03-21-2018, 11:04 PM
Helijib Helijib is offline
Helijib is on a distinguished road
David
Thanks very much for that info!
