Old 01-22-2018, 02:29 PM
Default Re: Beier sound controllerand light setup
Just got my beier and started programming sound for my 870k and then I'll setup led lights. I'm also usingb3s Lipo and had the same question. Fully charged 3s Lipo has 12.6v so which resistor did you use? The manual shows which one to use for nimh 12v batteries.
Old 01-30-2018, 09:18 PM
DrDiff DrDiff is offline
DrDiff is on a distinguished road
ifmys10: I bought my LEDs here... lighthouseleds.com. Since I have 3S Lipo batteries I used 12 volt pre wired LEDs.
For example the high beam headlights, I soldered the black wires (negative from the LED) on both sides together and then connected it to the appropriate wire from the rainbow harness. the red wires from the LED's are soldered together and then a jumper wire takes that to #8 on the left side of the soundmodule [the side where the power comes into the unit]
Originally Posted by liftmys10 View Post
Just got my beier and started programming sound for my 870k and then I'll setup led lights. I'm also usingb3s Lipo and had the same quest1ion. Fully charged 3s Lipo has 12.6v so which resistor did you use? The manual shows which one to use for nimh 12v batteries.
Dean Cory
Knox, IN
Currently Active Users Viewing This Thread: 18 (0 members and 18 guests)
