Old 02-15-2018, 01:47 PM
Default Re: ScaleArt Oil Cooler
Originally Posted by Widebody View Post
Well I have to say I’m disappointed with the oil cooler as it was smaller than I expected, 25mm by 25mm. No where on ScaleART website says the cooler size other than it comes with 4mm OD by 2.5 ID but the problem comes from the size of the fittings that are M3 bolt size with the hole inside the bolt only 1.5mm ID, so it doesn’t flow enough and slows down the complete hydraulic system and because of the restriction it’s creates its own heat in the oil, not ideal for a cooler. Hopefully this helps someone before they decide to buy one.
Pictures? Are you using the cooler before or after the pump?
Just to clarify, before would be the oil as it enters the pump and after is just the opposite.
Old 02-16-2018, 07:44 PM
Widebody Widebody is offline
Widebody is on a distinguished road
Hi,
It was plumbed on the return line to the tank, I assumed not to put anything before the pump as it requires the most amount of oil flow, maybe someone can correct me if I’m wrong. As for pictures I’m not sure as yet how to add them from my iPad.
Old 02-16-2018, 08:59 PM
Northern Farmer's Avatar
Hi,
Upload your picture to www.postimage.org and press the copy button and paste the link here
