Old 02-26-2018, 12:03 AM
Default Re: Metso Lokotrack LT120, Jaw Crusher.
Good to see you back it Kalle
Congrats on the house purchase & great job on the garage makeover, nice & bright in there now. Did you use LEDs for lighting?
Per your tig welds, they look better than mine, I still use my mig more than the tig. As Reg use to say, "gob it on & grind off the excess" ...though I think he does a lot less grinding off nowadays
Old 03-04-2018, 04:49 AM
Originally Posted by 9W Monighan View Post
Nice work as usual. I see you fixed the jaw teeth like we discussed last time. Hope this works out well.
I like seeing crushing equipment being built. I haven't had enough time to get more done on my stationary crusher.
Thanks!
Yeah, I had them made the right way this time.
I hope to finish this one and keep it, I will finish the crusher unit this winter and pick up next autum to continue with the frame, conveyor and feeder.
Thanks Joe,
Yeah, its a pleasure to work in there now!
No its regular armatures I have, I got these armatures for free from a friend. But I did went with another bulb (right word?) in them, these have a more white light then the regular used bulbs and are perfect for me.
Yeah you can always grind the welds but I think TIG welds are good enough looking even if they are quite bad, at least compared the bad MIG welds!
I really love my TIG welder, its so clean and you can do small welds, I just need to practice more to get more experience and less shaky hands!
Old 03-09-2018, 02:12 PM
Now it was time to turn the flywheel and the extra weight for the beltwheel.
I only had a 100mm chuck on my lathe and it cant hold pieces as large as the flywheel so I had an chuck adapter made by a local machineshop to get the boltcircle right and then I turned the last steps myself.
Now I can fit a 125mm chuck and this lathe will last me a few more years!
Here´s some progress on this project.
First I turned the internal hole for the flange mount on the spindle.
Then flipped it to turn the outer flange to fit on the new chuck.
I had 0.01mm runout on the spindleface with new backplate.
Here mounted and started to turn the flywheel, I had a runout on the chuck on about 0.03-0.04mm, that was measured on a drillbit in the chuck. Good enough for me.
And just a pic of my 10 year old chinese lathe, it has served me good over those years.
Also both covers are printed, also made on a cheap Wanhao 3D printer.
Old 03-10-2018, 02:28 AM
Rimrock Rimrock is offline
Fine machined and printed parts you got there. Have you evaluated adjustable bottom opening/distance of the jaws?
Soyland Industrier
Old 03-10-2018, 03:16 AM
Thanks!
I don't really understand how I can do that? Can you explain a bit more please.
Old 03-10-2018, 06:15 AM
Originally Posted by Azonic View Post
Thanks!
I see now you got a joint for a threaded rod as part of fixing the lower end of the moving jaw. Than one got the possibility for a adjustment, say +/- 5mm should do. manual adjustment is fine
Soyland Industrier
Old 03-10-2018, 10:43 AM
Now I get what you was talking about, I thought it was the jaws on the chuck!
Yes I have adjustable jaws in the crusher, I can adjust them probably 10mm in each direction.
