Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Scale Buildings, Warehouses and Structures.
Scale Buildings, Warehouses and Structures. If you have buildings and other structures that you have built to use with your Rc's here is your place to share them.
Old 03-01-2018, 05:53 PM
Default Re: Teardrop Trailer
Mustang you know how dogs are. "Get out of there, i need to take a pic.'' Nope, this is mine now.
Thanks hostile, it's going slow and styrene would have been so much easier than scale plywood.
I'm trying to decide on how i should do a window in the door, any thoughts?
Wombi, good to see you over here. Yeah, the hinges are scratch built from brass flat and tube, and a splash of solder. Once it's done the steel hinge pin will get cut down and crimped in. Suprisingly it wasn't as painful making these tiny hinges as getting leds into the Adam12 roof lights.
First thoughts involved plastic aileron hinge, copy the window hinge vertical, but those aren't right.
Plan A, solder tube to plate, make Z cut to seperate into leafs. Some day i might even find that part...
Plan 2, make L shapes from flat stock, solder on the smallest tube i can find, trim tube, file a lot until it looks and works ok. The hinges are mirrored so that the door is captive and can't lift off once pins are installed.
