#41
Another shot of the valve assembly:
![]() the hydraulic lines need to be trimmed and connected, I also need to run the lines between the valve assembly and the hydraulic pump. If anybody has any tips for bleeding the air out of the system please speak up. anybody know where i can find some kind of one-way tank vent. I don't want my hydraulic fluid spilling out if Im @ a weird angle. Last edited by Table Top Trucker; 04-02-2018 at 10:46 PM. |
#42
#43
Regarding the tank-vent one usually just go for a bit longer hose, with the end placed at a higher point under the hood
Soyland Industrier |
#44
As temperature in the system goes up and down you will want the tank to vent both directions so I don't think you would want a check valve in there. I know some full size vents will be ran into a seperate vented/filtered overflow tank
#45
Great job on the build and thanks for the pics.
Fumotec sells this vent filter: Vent As for bleeding the system, I just fill it with oil and cycle the cylinders with the pump running at slow speed, keep topping up the oil as needed and cycle cylinders until all the air is out. |
#46
so, i guess postimage is dead?? anybody have a suggestion for a replacement??
#47
here is a link to the latest video: https://youtu.be/YqmuZATpBn4
#48
Post image changed the rules a while ago.
https://postimg.org/image/.... needs to become https://postimg.cc/image/.... Let's try this. Quote:
Tags |
kit, lesu, liebherr, loader, wheel loader |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
