Old 04-25-2018, 06:26 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: Suitable gear mesh
Basically you just want a very little amount of play. If they are tight it will cause premature wear and excessive motor load. Too loose and premature wear quicker. A piece of paper cut close to same width of gear then ran between gears is basically what I do. Newspaper is thin, printer paper should do. Sandwiche it between gears tighten up and rotate it out.
https://youtu.be/xFGy8RARHN4
