Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
It's looking better and better. Will be interesting to see it fully painted.
Sorry for the long break. I haven't really had the energy to write up the documentation or actually do much work.
Lift mechanism for the telescopic floodlight mast. It technically works, but it could use some refinement, and I'm not sure how to mount it so that I can do maintenance on it later. I've been trying to figure out the best way to design the mechanism for this for more than a year. There's not much room and I want it to extend as high as possible. I would rather have a static prop than a telescopic mast that barely reaches above the roof. This version uses a micro servo modified for continuous rotation with physical microswitches and diodes cutting off power to the servo motor to stop at top and bottom. The rack and pinion is a drive belt harvested from an old RC car. ![]() ![]() ![]() One set of top mounted floodlights is done. Again using the 2835 LEDs (and again broke a couple while soldering) mounted in a plastic case that pops into the mounts. Round tube through a round hole is a pretty simple way to mount stuff, as it turns out. Why do I not have a 3D printer yet? I deeply hate making multiples of something. Just 4 more to go though. ![]() ![]() Started on the water level indicator lights for the middle pump module. ![]() Took out the mysterious but cheap fingernail tool again and scribed the last shutter. ![]() Simple mounting for the plates that the taillights are mounted on. I think I need a truck dictionary to figure out what everything is called. They'll probably be glued in eventually. ![]() Roughly started on the cab interior to find out where to hide the wiring. Fortunately the 1:1 P crew cab also has the engine in the middle of it, so I can make it reasonably accurate. I'm planning to hide the ESC under the rear bench. I'm hoping heat won't be an issue. I can't do much more work until I've figured out the wiring for the middle section. ![]() ![]() |
The middle module is where I'm planning to fit the battery, a huge pump, ESC for the pump, the BEC for the LEDs and micro servos, a voltage step up module, some switches and a distribution point for most of the wiring. I'm sure it's a brilliant idea to place a lipo battery and lots of sensitive electronics in the same compartment as a high pressure pump.
I found some 12v 30A switches that can hopefully survive the current. From right to left: Battery master switch, switch for all the extra electronics like arduino, lights and microservos and a master switch for the high pressure pump system. Building a small enclosure for them that will let me access the wiring behind them. ![]() ![]() ![]() |
