Old 08-13-2018, 11:50 AM
Rimrock Rimrock is offline
Default Re: 360l Hydraulics Upgrade
Originally Posted by Actros4160 View Post
Rimrock,
I agree with your comments about the upgrade to this type pump and valve blocks. I recently board a pump 1000ml mini pump with tank from this fellow,which is the main supplier for Premacon. https://www.modellhydraulik.com/. The pumps are industrial grade not toy grade pumps. SMC M-Series has this type fitting which Premacon uses as well.
https://content2.smcetech.com/pdf/M.pdf
I can defently see the resemblance to the ones Premacon got, and those compact ones are pretty interesting for smaller models. I mean I have seen one of them including the tank in the newest Fumotec excavator, PC290. Looks like they don't offer valve blocks yet.
Is that a 360 or 4200xl you have used the 1000 ml? If so how is the speed of the cylinders compared with the original pump?
Soyland Industrier
