Old 10-06-2018, 08:15 PM
Default Re: 1983-91 Econoline Ambulance
A single up firing 5mm led on each side of lightbar really isn't flashy enough, so i did this...
Mounted a set of led rotators that have 4 light modes. Fast rotate, slow rotate, double flash, strobe.
Found out 'Wiggly Eyes' are the answer to my clear ditch light lenses!
Circuit to go more flashy.
https://www.electronics-project-desi...d-flasher.html
The 470 ohm resistors out goes to red led, added a 100 ohm set for the white led.
555 chip pinout
https://www.jameco.com/jameco/worksh...-tutorial.html
Hack servo, attach a diode at motor output and connect. Epic fail.
Get a "2 ch remote switch", hook THAT up. Like an absolute boss.
Gotta add some other remote circuits:
. Box corners / grill / aft wall. Alternating flash circuit. Sw ch.
. Rotators in lightbar.. 4 modes, Need y-harness a stick ch.
. Ditch lights. All sides together on Sw ch.
Normal car lighting control board - no penalty uses turn/burn channels. Gives headlight, taillight, brake, turnsignals, reverse, markers, and a few modes i don't even want.
Need to add holes for backup, rear turnsignal.
Front turnsignal needs two 3mm to give running & turn. Also painted the turnsignal lenses
That leaves 1 channel of my 6 for a siren if i can find one i like. Leaning toward an Evan Design police siren.
If i need more channels, i've gotta hack the FSI6 into the 10 ch it can be. Plus get a bigger rx
